I can put chapter 1 in track 1, and put chapter 2 in track 2; or I can put chapter 1 & 2 in track 1. What's the difference between these? Thanks.
Each track is a separate video. Each video will have chapters.
If you put 2 videos with 4 chapters each in the same track, that track will have 8 chapters. The main menu will show 1 title with a link to the chapter menu(s) and a "play all" button.
If create 4 tracks, and each track has 1 video with 3 chapters, the main menu will show 4 titles with links to their respective chapter menus, along with a "play all" button.
If you have a video with chapters and want to do as you said, ou would have to split up the video at those chapter points, but it would no longer be 1 video. -
Hi zhou_thomas,
You need to do some reading on what a track is and what a chapter is. Then you'll understand how tracks and chapters are related, and so how they can be arranged.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
