Can any one suggest me where to get a PAL to NTSC convertor (Digital) for a cheaper price?? (less than $75)
Your help is appreciated!!!
System converters are expensive, and you will not find anything for $75 that will convert the frame and line number. The cheapest is the CL-1585? which is priced at $280 or so. Next step up is a converter with S-Video in/out, and it will be around $500. Check ebay for any used units.
Any converter costing less than $150 do not convert the frame/line rate, but simply convert the color sub carrier. Without full conversion, you cannot record the video, and it will not be displayed correctly on many TV's.
how to test Pal/Ntsc converter box?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2009, 10:28 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21 -
Would a Digital Video Stabilizer work for a PAL tape in an NTSC vcr?
By ChaunceyK in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2007, 12:42 -
Converting a TV box set from PAL to NTSC
By Slamtastic in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2007, 14:28 -
Anyone Ever Heard of Digital Media Converter Pal to NTSC
By mn072065 in forum Video ConversionReplies: 5Last Post: 9th Jun 2007, 21:50
