Hi,
I'd like to bye a dvd write but I don't know excalty which model to choose.
So which is the best (for compatibility with standalone players and all medias).
Nec ND-2500A ?
Pioneer DVR 107 ?
I wait you responses.
Results 1 to 22 of 22
options are....nec or pioneer, or maybe lite-on.
if you want bitsetting, then nec, if not, and you can spend more, then pioneer....
i own a nec for 1 year, and love it.... -
I have owned a Pioneer 105 for a year and burned over a 1000 DVD's with only 25 coasters. I used only Ritek Media. Then I decided to purchase a Pioneer 107, and so far have burned 250 Ritek's and 100 Prodisc with no coasters at all. So I really like the Pioneer's. I only use DVD-R media.
Hope my 2 cents helps. -
I have a Hp300i dvd+ burner.....have used it to make over 150 dvd back ups, and many cds, without a single error, or problem issue. Bought for $300 just under 2 yrs ago.
What We Do In Life, Echoes In Eternity.... -
Get a BenQ DW822A. You get officially support dual layer in Sept. and bitsetting now and the quality and speed is superior to most. It can do a number of 4x brand DVDrs at 8x. Go with this one if you can live with mainly sticking to + although it will do - .
Get the NEC, it has dual layer firmware NOW that is FREE and burns great.
I agree with gitreel buy what you can afford. Remember that every dvd burner has their pros and cons. No one burner is the greatest and there are many variables when authoring, backing up and burning dvds. -
Originally Posted by budz
Is it true that the Pioneer DVR107D has problems with cd audio extraction at the end of cd ???
I see that on a test of the pioneer DVR107. Maybe the last firmware corrects this problem. -
Don't use it for ripping so would not know, don't want to knacker the laser.
This HP 8X Internal DVD+/-RW Drive is awesome. It's now $179.99 with $30.00 mail in rebate at Circuit City -
i've got the 107. no problems with it. i have a friend who has the nec - he says that's very good. as someone said earlier - let your budget decide - there's no real difference at all. both write dvds and cds with equally viewable results.
For -R media, both the NEC 2500 and Pioneer A07 are great choices.
If you plan on using +R media also/only, I'd opt for the NEC 2500 with the bit setting firmware (hack), or the above posted HP 8x DVD+/- drive. The HP drive is an NEC, with HPs own tuned firmware, which supports bitsetting without the need for a hack.
BenQ and Lite On are both releasing new drives real soon, if not already. These are 12x (12x +R/8x-R) models, and +DL models (2.4x +DL, 8x +/- R) -
Don't get an Optorite cause it may be a pain in the ass. If you are very cheap however, it is an option.
Originally Posted by cd090580Sam Ontario
Originally Posted by 888888
I've owned a Hp300i dvd writer for about 2yrs now. Done 150+ dvd backups, 30+ cd-r, 7 mp3 data dvdrws, etc.. All done flawlessly (no coasters/errors)
I apologize for this latest reply.....I didn't read all the previous replies and just noticed that I posted a reply to this thread on march 12th...sorry for the repeat post....But I still recommend the Hp 300i.....What We Do In Life, Echoes In Eternity.... -
I've owned Lite-On 811S, 851S, Pioneer 104, 105, NEC 2500.
My choices for quality burns with most media would be Pioneer or NEC. I wouldn't use either one to read or rip, for that use a DVD-ROM. -
Originally Posted by quadforce
dvd writer help
By Stephb in forum DVD RippingReplies: 2Last Post: 2nd Feb 2009, 15:38 -
dvd / cd writer
By bill gailer in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jan 2009, 21:18 -
After a new DVD Writer..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 10:01 -
new dvd writer problems
By carstd01 in forum DVD & Blu-ray WritersReplies: 6Last Post: 25th Nov 2007, 12:58 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 00:08
