Does anyone out there have a solution for the mili-second pauses that occur on copied dvds. On certain movies "Honey,Master and Commander" for instance there is a video pause that doesn't affect the audio but is noticeable. I use DvDshrink and Dvddecrypter and Intervideo to burn the disc. It doesn't do on all of the dvds just a few. I have been using diferent media maxell, tdk, memorex,verbatim, i have burned good discs on all of the aformentiond media. What could be the problem? Thanks in advance![]()
What speed did u burn at? sometimes when burning at X4 and above the video gets jumpy/min-pauses especially between chapters. i know it's a very big difference for me when burning at X2 then at X4...
With all due respect... and there is respect... -
When the original movie is copied to the hard drive if it's a dual layer DVD there will be a brief pause when it changes layers. If it's only doing it on some movies maybe it's because the other ones are single layer.
If it's too loud, then you're too old. -
I have never used intervideo to burn DVD's, the most popular, and through my experience, the best burning software has to be nero... d/l a trial version and see if that could be the problem... I had a nightmare trying to burn DVD's with a few different programs until nero saved me from a room full of coasters!!!
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
MPC-HC : audio does not pause when video pauses for H264 video
By kswartz in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2011, 02:56 -
How to get max clear stills, when pause a video - should I deinterlace??
By vantechmag in forum EditingReplies: 2Last Post: 11th May 2009, 18:55 -
video uploader w/ pause
By zoobie in forum Newbie / General discussionsReplies: 0Last Post: 1st May 2009, 23:16 -
Pause video using Avisynth
By roglopes in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2009, 15:41
