I am using DVD shrink, and was wondering if it was possible to force them to burn it at 8x. Any help would be appreciated.
If this has been covered, I couldn't find it in the search sorry.
well for starters you have to give all your system specs as we need to know what you are talking about. there is also a huge dvd media topic on left column.
I have an NEC 2500 8x DVD burner. My pc is an athlon xp 2600+ with 1 gig of ddr 3200 ram. 200 gig hd and am running win xp pro. I bought some Ritek G04 1X-4X DVD-R. I have been using DVD shrink to back up my media, and then it will start the burn process in nero. I was wondering if there was a way to make it burn 8x, even though my disks are 4x.
check the NEC forum for information at cdfreaks.com
http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=30&f=86 -
I think the rating on the media is the recommended highest speed from the manufacturer. I know with CDRs I had some that were rated at 32X but could be burnt at 52X.
Generally it is because when the 4X media was released, the best burners were 4X. The media could quite possibly be burnt quicker than that, but the manufacturer would look stupid calling them 8X discs when 4X burners are the quickest available. Having said that, some media is locked in the speeds it can be burnt at.If in doubt, Google it.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 03:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
