Hi,
Can anyone recommend the best DVD or good recording software. I have Intervideo DVD copy, DVD Shrink and Clone CD already. But after I shrink the video in DVD Shrink I want to be able to use a good software to burn to DVD.
I also would be using for PS2 backup and XBox backup. IS there anyone program that does all and is good or what would be best for each.
My firends recommed different software and due to this I am confused. 1 uses DVD Shrink and Nero. The other uses DVD Shrink and Prassi. And another uses Prassi for PS2 backup.
I have a NEC 2500A with the new 1.07 firmware.
for XBox backups, you cant just copy it in a computer drive I hope you know...but DVD Decrypter can be used to burn the ISO once you create it by FTPing into your XBox. You can also use it for PS2 games, and movies.
Actually once you get your xbox files you must assemble them into xbox format with Xiso or some other program. You CANNOT copy xbox games directly they are in xfat format.
For the ps2 use only -r media, 2x max, Nero: dvd copy. Prassi is too old for your 2500.
Free Backup DVD software -DVDFab Passkey
By jimdagys in forum DVD RippingReplies: 3Last Post: 9th Mar 2010, 14:52 -
Hello All. I need a Free Backup Software to replace DVD Fab. Any ideas?
By Bamahusker in forum DVD RippingReplies: 89Last Post: 13th Nov 2009, 20:16 -
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2009, 23:36 -
DVD Backup Software
By peebee23 in forum DVD RippingReplies: 7Last Post: 9th Jun 2009, 21:39 -
Video editing & burning software
By katz68 in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2009, 15:58
