Hello,
I have a Panasonic DMR-E50 Recorder. When I'm done recording a VHS to DVD, I finalize it and then use the recorder to check the audio which turns out fine. I then try the DVD-R on the DGE GE 505N DVD Player and the sound is fine there too but when I try the disc on an RCA RC5510p DVD player, there's no sound at all. I'm thinking it's the audio output from the recorder on the Audio screen from setup that's the problem? What should the settings be when recording?
What if changing the audio output from the recorder doesn't help? I also have the recorder connected to an old amp receiver. Could it also be the connection? I'm not sure about that though because it works on the DGE GE 505N DVD player.
The E50 records in Dolby Digital (AC3). Are you sure your RCA player is compatible with that? By "audio output" do you mean the format? If you've tried LPCM audio and it still doesn't work then you have other problems. I still think it's a player issue or a cabling issue with the additional amp.
I think the problem, probably lies in the player itself not liking the media. You say it is hooked up to an amp, what does it sound like through the tv speakers normally ?.
Originally Posted by Hardcoreruss
I have tested the discs I made over my neighbors and they work fine there too. Very strange.
Playing dvds recorded fron tapes on a Sansui dvd recorder, on a LG RH399H
By Eric2011 in forum Video ConversionReplies: 11Last Post: 6th Jul 2011, 04:56 -
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 16:55 -
Standalone recorded DVD playing in a Mac problem
By tigerdad in forum MacReplies: 4Last Post: 5th Aug 2008, 20:28 -
Help! DVD recorded from TV not playing on Laptop
By dvdude in forum Software PlayingReplies: 5Last Post: 23rd Mar 2008, 18:01 -
[SOLVED] Playing recorded DVDs on the computer (Samsung DVD-SH853)
By ToniVC in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Nov 2007, 13:59
