I am using Nerovision Express to compile 3 videos and a slide show onto one DVD. I get everything created correctly and have one menu button for each item but when I play any of them it automatically plays the next item instead of going back to the main menu. I'd like it to act like a normal DVD in that when you play the first video it ends and takes you back to the main menu so you can choose what you'd like to see next.
Does anyone know what I might have wrong that is resulting in this non-stop playing and how to fix it?
I don't think Nerovision Express has that option.
It's designed to add one video, or a sequence of clips, and play them back in the order they were added.
I can find no option to return to the menu after playing clip 1, in order to manually select another clip.Cheers, Jim
My DVDLab Guides -
Thanks for the reply. I can't believe the software was designed this way. Why even have a menu system then? Crazy stuff. I will need to find something else that can do this for me then.
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
