Sorry, I guess my previous question was pretty vague. I actually have been reading a lot of the HOW to guides and maybe I already got the answer I'm looking for --- There is No "best".
My real question is about VHS to DVD conversion. I've used VirtualDub to cature from my KWORLD TV878RF-PRO TV Tuner / Video Card. I captured at 720X480 , 29 fps , and saved as an AVI. I did some minor editing and burned it to a DVD with Roxio Creator 6. It actually played great and looked pretty good.
I guess I was just looking for the "best" formula for VHS to DVD (ie. 720X480, 29fps, YUY2 (after read about data format, I'm still not sure which custom setting in VirtualDub to choose on the Data Format YUYV, YUY2, etc.) then burn at MPEG1 with such and such resolution etc.
These home movies are really important to me and just wanted to preserve as much quality as possible, even if it means buying a new capture card.
System Specs.
P4 at 2.5Ghz , 512RAM, 200GB hard drive, KWORLD TV878RF-PRO
(I've been using the coaxil cable just because my old VCR doesn't have an S cable out)
If you want the best possible quality, buy the Canopus AVDC100 analogue to digital converter. Then you can capture from VHS to DV via a cheap firewire card. No messing about. Thats the way I do it.
Originally Posted by thebignewbie
What kind of compression did you use?Originally Posted by thebignewbie
If you're happy with the results, good for you. I would do things differently. Instead of encoding, authoring, and burning with Roxio, I would probably just use it to burn only. I would use a dedicated mpeg encoder such as TMPGEnc to convert to mpeg-2 using a resolution of 352x480. This is the resolution that is closest to the actual frame size of VHS. Using 720x480 would be overkill. Using the smaller resolution would allow you to put more footage on one DVD because it doesn't require as much bitrate. You don't need to use any more than 5000kbps. Once you have your DVD mpeg created you can author with something like TMPGEnc DVD Author. I'm not sure if Roxio will be able to import the mpeg you create because of the resolution. It might attempt to re-encode. TDA is easy to use and creates pretty good menus. You can either burn your authored VIDEO_TS folder with TDA or with Roxio.Originally Posted by thebignewbie
First of all, why would you want to use mpeg-1? You should use mpeg-2 for DVD purposes. Secondly, you really don't need to worry about the data format in Vdub. Once you make your cuts, set the video menu for direct stream copy and save. You don't need to recompress for simple trims and cuts. If you require more serious editing like effects, titles and transitions you should use another editor.Originally Posted by thebignewbie
Unless you are unhappy with the end result you should keep what you have and try to get the most out of it.Originally Posted by thebignewbie
Your system if fairly well suited for the task at hand. The only advice I can give you in this area would be to get a DC block from Radio Shack. It's a cheap little device that connects to the coax cable that prevents interference from other electrical equipment. It might help clean up the picture if you are experiencing any "fuzzy" distortion.Originally Posted by thebignewbie
To recap a bit, the order of succession that I would advise for this process is:
1. Capture
2. Edit
3. Encode
4. Author
5. Burn
Hope this helps. Bear in mind that this is merely my opinion. Other people here may suggest an entirely different course of action. You will have to conclude what you think will work best for you. Good luck and have fun. -
I use the same Kworld card occasionally, it is on my backup system. When I capture, I have it set for 352x480, 29 fps, YUY2 for VHS capture (through coax cable). I also use the PicVideo codec set on 19 for quality in VDub. I use Tmpgenc to convert to MPEG-2 usually (sometimes to MPEG-1). I generally use the default settings. The audio is captured uncompressed then edited and cleaned up. I then convert to AC3 for DVDs. Then Tmpgenc DVD Author to create DVDs or VCDEasy for VCDs.
I think that the video capture is the easiest part, getting the audio clean is the big pain in the a$$! -
My method is best to me:
www.digitalfaq.com/digitalfaqway.htm
Lots of others have said they like it too.Want my help? Ask here! (not via PM!)
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 23:34 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 13:14 -
Editing, Creating DVD from "Microsoft Recorded TV show" format
By mb90078 in forum Media Center PC / MediaCentersReplies: 6Last Post: 8th Aug 2008, 20:40 -
How to get ".PVR" files converted to a DVD format ?
By shaynefromkyneton in forum Video ConversionReplies: 5Last Post: 3rd Aug 2007, 00:50
