When running Mcafee virus scan last night it came up with a proxy-navid??? in system volume information\restore and told me this could not be cleaned it will also not delete or quarantine it. The solution it came up with was to replace with a clean version but i don't even have a clue what this file is.![]()
I'd appreciate any feedback you might have.
p.s that is not the full file name it is followed on by a load of numbers and letters if this is needed for better info please let me know
Go to Control panel > system > System Restore tab and turn off system restore for all drives.
Reboot your computer, then go back and restart system restore and create a new restore point in your help menu.
WARNING - this will delete all of your previous restore points.
Since it is in "system volume information\restore" I wouldn't really worry about it too much it is not a virus operating on your system, it is a virus that was on your system at the time you computer made a restore point and unless you happen to restore your PC to that point of infection it shouldn't be a problem.
Help me decide on a Proxy format!
By Domiel in forum EditingReplies: 2Last Post: 22nd Nov 2010, 09:38 -
Question about virus so terrible that Ghost restore did not kill the virus
By jimdagys in forum ComputerReplies: 24Last Post: 27th Apr 2010, 10:58 -
Web / Proxy Anonymizers…
By retroborg in forum Off topicReplies: 1Last Post: 30th Dec 2009, 09:47 -
VIRUS,VIRUS, Getting blocked accessing antivirus sites
By G)-(OST in forum ComputerReplies: 11Last Post: 10th Apr 2009, 02:40 -
why do people use proxy sites?
By Rudyard in forum ComputerReplies: 5Last Post: 5th Mar 2009, 09:19
