how do you merge 2 files in goldwave?
The way I would do it is:
1. Open clip number one, then clip number two. Let's assume that you want to join clip number two at the end of clip number one.
2. Select clip number two as the active window(click on the title bar). Go to Edit>Marker>Set, then click OK. Click on the copy button in the toolbar.
3. Select clip number one as the active window. Go to Edit>Paste at>End, then save as your desired format.
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 22:50 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 12:15 -
another simple question about FCE and iDVD... =)
By ednarophati in forum MacReplies: 1Last Post: 31st Jul 2007, 11:15
