i have started getting problems with the orange bulkpack disks. after i convet the avi to mpeg (tmpegnc) and then to .vob(tmpegnc authour)
i burn onto these disk using nero 5 but when i play them back on the ps2 the films get about 3 quarters of the way through then they start to get a bit jerky then it comes up cannot read disk.
i have tried fully reinatalling windows but it still does it. and my first 50 odd disks were fine but the rest have cut out.
should i try different media?? if so, what is a good cheap disk??
I have been using the orange BulkPaq discs for ages now, and I haven't had a single problem with them. However, my PS2 is never very happy to play them. It's not a very good DVD player for compatability, unfortunately.
You could try Infiniti media.
Cobra
What happened to the orange cone? Vertical Lines in deep reds and oranges.
By Sullah in forum Video ConversionReplies: 12Last Post: 24th Jul 2011, 17:01 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
The same OS installed on two disks
By Jomapil in forum ComputerReplies: 29Last Post: 4th Jun 2009, 16:35 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
Movies on the new HD disks... why?
By Marco33 in forum Off topicReplies: 10Last Post: 24th Jun 2007, 13:34
