I have VideOH (Adaptec), with USB1 capture device, also Pinnacle Studio 8 also with USB. I decided to capture with the former since with the latter you have to drag and drop everything one by one to the storyboard. I also have Video Studio 6 (software only) since I took the product back. I need to know what is recommended for the following:
What is the best of the 3 capture devices I have?
What is the best edit device?
What filters would produce the best quality for dvd playback.
What settings in Virtualdub/Tmpgenc need to be adjusted and to what?
What compressors, if any, should be installed?
Should I increase the 15fps framerate, if so by what approx/exactly?
People have replied rubbish in and rubbish out. On some of my videos the quality is excellent, so should it not be excellent in excellent out? Admitidly some were LP video-recorded but the end result is still pretty ok.
My OS is a Windows XP (Home) Dimension 8300 with 80GB+120GB storage. Pentium 4 Processor
As u have probably gathered I am new in this field but feel if these questions were answered satisfactorily they would set me and many others on our respective ways to better VHStoDVD quality and by the way I don't have a DV Camcorder only an Analog.
Thanks for taking the time to read this message and look forward to hearing from you all soon. Clive
THREE? I counted 2. anyway......
You will not get satisfactory results from a USB1.1 device.
Huh ?! - You mean best editing software. There is no best. There is what is best for your needs. I started out using VirtualDub and have sinced move to Adobe Premiere 6. I still use VirtualDub for simple cuts and 'direct stream copies'.
You are confused. Filters will have no affect on the dvd playback. They can however assist in "tweaking" the VHS source file. Example : filters could be used to sharpen the image or resize it.
For that you need to read more .... lots more . Read the guides. Specifically some of the VHS to mpeg2 guides.
CODECS . Suggest HUFFYUV but for that you may need a PCI/AGP type video capture card and not a USB device. (never used a USB capture device so i am not sure if it will regonize the huffyuv codec)
Hmm YEAH ! - EXACTLY 29.97 (30) FPS is NTSC , 25fps PAL.
....*sigh* :P
Honestly you best bet is a stand alone recorder. There are so many ways to convert VHS to DVD .Read up some more and post back - the USB route will give you nothing but grief. -
If you're serious about capturing VHS on your PC you should look into getting a good capture device like one of the Canopus units. You can worry about filtering and editing later. The most important thing is to get a good clean capture. The USB 1.1 unit isn't going to cut it.
Perhaps I should have said the best quality on the cheap. I did once manage to capture and record a 90 min TV Movie from a vhs tape called The Hitcher and that came out viewable after cleaning up as best I understood with the filters. But it took me about 15 hours to encode! I am not looking for miracles but just something I can watch without it jumping up and down and that wont take that amount of time to encode to mpeg2.
The feedback I am getting tells me that good quality capture is not possible unless I invest in what do u call it a Canapus capture card which no doubt is going to set me back quite a bit and the other capture devices would then become obselete.
I had thought about a recorder but then I want to purchase KISS DP 558 divx/mpeg etc player which records from the tv onto its built in 80GB & via ethernet adapters can be downloaded onto the pc. So I am in a dilemna of where to turn now.
I would just like to know if anyone has captured reasonable viewing from a USB1 capture device and if so what filters did they use to clean it up?
Thanks for coming back to me so promptly. -
Not necessarily true and I don't think teegee is saying "only a Canopus capture device will give good quality." I use a Wintv (401 model) card and I am satisfied. Total cost $60 ebay.Originally Posted by lingoguysw5
USB 1.1 devices have gotten a bad rap. I havn't heard much about the USB 2.0 devices. Are you certain that adaptec device is 1.1? I thought I looked into those a while back and they were 2.0.Originally Posted by lingoguysw5 -
The best capture is a Panasoni dvd recorder, about $224 at Target. Has the best filters, ease of use, etc.
That's just your opinion. There are people who would say that using a PC capture solution is best. The truth is that there is no "best" What might be right for you, may not be right for some. A man is born, he's a man of means. Then along come two.........Originally Posted by handyguy
Filters for restoring old VHS
By elbenno in forum RestorationReplies: 48Last Post: 5th Dec 2012, 16:47 -
What are the best filters for VHS captures?
By mpwr5 in forum Video ConversionReplies: 12Last Post: 2nd Oct 2010, 02:52 -
I can't edit my dvd's (former vhs)
By RoddyN in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2009, 00:47 -
VHS to DVD OR HARD DRIVE TO EDIT WITH THE BEST QUALITY
By jakeconnor in forum Capturing and VCRReplies: 11Last Post: 9th Jul 2008, 22:04 -
Vdub filters on my HI8/VHS before Authoring..
By nopk in forum RestorationReplies: 6Last Post: 8th Dec 2007, 18:34
