Hi guys,
Just want to preface by saying that this site is great and all the advice you guys give is very helpful.
Okay, I was trying to edit a Divx file with the Virtualdub program--basically trying to cut a part of the clip. Well, I follow all the directions from one of the guides located on the website and all goes well. The program starts processing the file and on the program's menu, it projects the saved file to be 7GB!!!Is the saved file supposed to be that big? The original video file I was editing is only 10 minutes long and about 100MB.
Is it supposed to be that large or am I doing something wrong? Thanks all for your help.![]()
You must select Video -> Direct stream copy to use the original video. It will limit you to cut only at keyframes, sometimes 10 seconds interval on DivX, to cut more accurate you need to recompress (Full processing mode, then Video -> Compression, select divX. ). Quality loss must be expected.
VirtualDub Output question...
By nharikrishna in forum EditingReplies: 8Last Post: 22nd Nov 2010, 23:27 -
VirtualDub question
By s3r19lk1ll3r in forum EditingReplies: 5Last Post: 15th Oct 2010, 17:43 -
VirtualDub question
By Rogert in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2009, 12:22 -
virtualdub question
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 13:34 -
virtualdub question
By cowboysroy31 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 12:50
