Okay, my temps are within range of what is "acceptable" but they still seem a bit high to me. I have even been close to the max temp point a couple times under heavy loads. The problem, I believe, stems from my side fan blowing air OUT instead of IN.
I currently have 1 fan in front blowing in, the fan on side blows out as well as the two fans in the back. This is how it came from the factory (I am not that computer literate).
Now, when I take the side off and have a fan blowing on it, the teamp didn't raise above 55C for over 10 minutes at 100%. When I had the side of the case on, and under about 5 minutes of 100%, it was up to 67C. So, this tells me my theory is correct.
So how do I go about getting the fan to blow the right way? I really don't like having this setup (note, the computer is usually in the left of the desk, not under the desk like it is now:
i believe you can just reverse the positive and negative wires going to the fan. im not positive, so hopefully someone else will know
haha, perhaps I should have looked a bit harder before asking.
I just had to turn the fan and point it the other way -
Changing the wires will not help you..
Just remove the fan turn it around and reinstall it.Rick -
By reversing the wires you could burn out the fan. Just physically flip the fan around.
Originally Posted by shelbyGT
The little arrows imprinted in the plastic frame, right?
It's OK. Everybody's entitled to an Indolikaa moment once in awhile. Now let's talk about your RAID-0 setup... :P -
We could talk about it. All I know is that it is one big honking hard drive (okay, 2X120, whatever). I'd like to split it up into smaller ones, but like I said, I'm not that handy with computers (as can be seen above). If it ain't broke don't fix it!!!
Blowing-up letterbox
By carlmart in forum Video ConversionReplies: 13Last Post: 1st May 2012, 14:56 -
Case fan not spinning
By beavereater in forum ComputerReplies: 18Last Post: 15th Sep 2011, 14:51 -
Blowing 4:3 cropped video to 16:9
By carlmart in forum Video ConversionReplies: 4Last Post: 1st Jun 2011, 09:40 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 15:54 -
500GB seagate drive at bestbuy (I'm blowing off some steam here......)
By Webster in forum Off topicReplies: 20Last Post: 8th Oct 2007, 12:16
