  1. Any ideas why i cant watch VCDs or SVCDs when im using Powerdvd 5.
    The speed is too fast. It seems like it plays the first 5secs of a chapter and then moves to the next and so on....
    When im using Windows media player everything is normal!
    I should mention that the (S)VCDS are bin&cue mounted in a Virtual drive with Alcohol 120%.
    This is also happening with powerdvd 4.
    any help??
    thanks
    A.
  2. Apparently this is a known bug, if you d/l this patch http://www.gocyberlink.com/english/download/dl_patch.jsp?dl_id=139&ProdId=1 hopefully you can watch them normally... doesn't actually say anything about it on the support site though, so it might not be what your looking for, but its worth a try!!
    Hope this solves your problem!!
  3. it worked!!!
    thanks man!
