I have an XviD that I'm trying to convert to SVCD. I have Nimo's Codec Pack and XviD-1.0-05042004 _Release Candidate 4_ installed. I still get the unsupported error in TMPGEnc.. Is there something I can do?
Results 1 to 14 of 14
The first thing I advise is that you get rid of that Nimo pack. If all codec packs are evil, Nimo has to be none other than Satan. Stay away from codec packs. They cause more problems than they solve. If you have a movie that doesn't play, find out which codec you need with G-spot and install only what you need. You can find most codecs in the tools section here. As for the TMPGEnc problem, if the file is actually Xvid(confirm with G-spot), FFDSHOW should allow it to be opened.
Well, in DivX Player, it plays fine. The 4CC is DIV3 (Name = DivX 3 Low-Motion). Hope this helps you help me
I installed FFDShow, but now the video just crashes. After 2 seconds, GSpot, Windows Media Player, and DivX Player crash. TMPGEnc still gives the unsupported error. I got rid of Nimo's Codecs and DivX, then installed FFDShow and DivX after that. Same problem
You might want to try changing the 4cc to DIVX instead of DIV3. I can't find a link to a 4cc changer just now but you should have one if you have the latest xvid codec installed. Check the "XVID" folder in your program files directory(usually C:\Program Files\Xvid).
If that doesn't work you could try Frameserving With Vdub. -
Ah, k. Thanks for your help everybody! Just as another little question, should I install DivX (from www.divx.com), and then afterwards those XviD codecs at http://www.roeder.goe.net/~koepi/xvid.shtml ? I don't think I'll install that Nimo Codec Pack anymore unless I need a codec I don't have from XviD/DivX.
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 10:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 12:56 -
.3GP File currupted o unsupported
By MikeDinner in forum EditingReplies: 2Last Post: 31st Mar 2009, 05:02 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 18:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 21:31
