ok, I am using my sony dvd burner to burn movies using tmpgenc to convert the movies and then later on tmpgenc dvd author to make titles and stuff and also to burn, but after a couple of movies I burnt, I noticed this big problem, the movie skips, a lot. Could it be because I have a dvd burner which is a USB 2.0 device connnected to a regular USB port so the movie dosen't get burnt porperly? or is it some other reason???
Thanks in advanced, Lucasiga
Results 1 to 13 of 13
What do you mean by a "regular" USB port? Do you mean a USB 1.1 port? Did any movie ever work?
Anyway, I'll employ a 100% valid "pat" answer: Your recordable media sucks. Try burning with some quality media.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
What slk means is use a better quality blank dvd it seems the one you are currently using is cheap and the dye on the disc is of poor quality and that is why your dvd's are skipping. and finally the usb port has nothing to do with the skipping it's truly cheap media,for example try riteks or even tdks you can find them at good prices at www.meritline.com they are great ..
Speaking of quality media, I am contemplating ordering a 50-disc spindle of Taiyo Yuden 4X discs from a retailer in Queensland that is offering them for $68. Good deal? Or should I look elsewhere?
http://www.thediscshop.com.au/moreInfo.cgi?cat=DVM-TAY-501X
That's the ad I am reading at the moment. It took me a lot of searching to find this retailer. I dare say that a lot of businesses would be in trouble if these people set up a shop where I am living right now. -
really?!? where do you live then???
they have about 5-6 shops in South East Queensland
price is ok - a couple of times in the past they were using rebaged princo's but I think that's stopped now... -
A place called The A***hole of the A***hole of the world, or Maryborough as its residents refer to it.
I've decided to give these discs a try and see how they perform. They can't be much more annoying than the Datastream or Media Cache ones I've tried before. -
Let us know how you get on. I can't find any prices that good in Victoria unless you buy Princo.
Will do. If you can't get prices that good in Melbourne, I would recommend giving these guys your business until you can. At least if my test of the discs I am going to order goes to plan.
haha lived in Maryborough for a year and hated it!
I'm pretty sure the the closest Disc shop is sunshine coast - order from the Mansfield office - it's kinda HQ -
If your in Melbourne,
I bought a 50 pack of Ritek G04's for $60 from the swap meet
I bought it from Annie who seems to be well known, shes in box hill
Im interested in how that 50-disc spindle of Taiyo Yuden 4X discs perform as well
RiData - what happened to them?
By akkers in forum Authoring (DVD)Replies: 4Last Post: 23rd Apr 2012, 11:24 -
What happened to Ryan?
By Jomapil in forum Video ConversionReplies: 6Last Post: 16th Jun 2009, 14:14 -
What happened to gstring?
By jgombos in forum Software PlayingReplies: 4Last Post: 18th Feb 2009, 13:59 -
What happened to the Site?
By VideoMan in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Dec 2007, 06:54
