ive used the newbie guide on this website to rip hollowman recently,the aspect ratio is 16:9 in dvd2avi,when i use tmpgenc to encode my svcd the movie comes out fullscreen,i set the input ratio correctly,is there any other settings not mentioned in the guide that i need to make?
thanx
jonx
No, and probably you didn't set the ratios correctly.
Did you crop the borders with dvd2avi or TMPG?
What are your settings? (aspect ratio, source aspect ratio, video arrange method, clip yes/no) -
There is another possibility:
the movie is anamorphic. This means that the movie has an aspect ratio of 16:9, but is stored in fullscreen. (the movie is stetched vertically) DVD2AVI will display 16:9 as the aspect ratio.
In such a case TMPGEnc will encode also anamorphic fullscreen. If you have a widescreen television set, the movie will look great, and the aspect ratio will be correct, as the TV set will strech the movie horizontally.
If you have a 4:3 TV set, the persons in the movie will probably have "eggheads"
To verify if the movie is anamorphic; open the VOB's in DVD2AVI and check how the movie looks in there. If the aspect ratio is 16:9, and the movie is fullscreen, then you know the reason.
If you do not want the movie encoded as anamorphic, then change the source aspect ratio.
If the movie in DVD2AVi has black bars, then it is not stored as anamorphic, and you can use TMPGEnc to set the aspect ratio right, as Truman has suggested.
The Dutchman
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
