Hi. My problem is, that it won't burn my dvd's. When I put a dvd-r in and press burn it makes an error a few seconds later. I have unchekked reallocate VIDEO_TS because I have made 1 out of 7 and the one was with reallocate unchekked. But when i put a rewritable in i doesn't have any problems please help me. My firmware is 1.07 and I'm really desperate because i used dvd decrypter for a time, but recently it won't burn it says semafor timeout period expired. My log for imgtoolsburn is this. PLEASE HELP!!!!
Can't open INI file (C:\Programmer\ImgTool Burn\ImgTool.ini),
using default settings...
Opening NeroAPI.DLL
Nero API version 6.3.0.2
Initialization of the NeroAPI successful.
Found the following devices:
PIONEER DVD-RW DVR-106D
Image Recorder
Opening NeroAPI.DLL
Image Recorder
Disable VIDEO_TS Realloc...
Starting Burn Process...
Using Device "PIONEER DVD-RW DVR-106D"
Using ISO Flags: ISO UDF DVD CMPT
try to building DVD ISO Tree...
Start path: "E:\DVD'er\Til_Brænding\Man_On_The_Moon"
AUDIO_TS dir present...
VIDEO_TS dir present...
Adding files in directory "E:\DVD'er\Til_Brænding\Man_On_The_Moon\AUDIO_TS". ..
building VIDEO_TS Tree...
Adding VIDEO_TS.IFO
File: "VIDEO_TS.VOB" doesn't exist ==> create ISO without it!
Adding VIDEO_TS.BUP
Adding VTS_01_0.IFO
Adding VTS_01_1.VOB
Adding VTS_01_2.VOB
Adding VTS_01_3.VOB
Adding VTS_01_4.VOB
Adding VTS_01_5.VOB
Adding VTS_01_0.BUP
Adding files in directory "E:\DVD'er\Til_Brænding\Man_On_The_Moon"...
Writing on DVD Media...
Using Speed: 2.0x (2770kB/s)
===> DVD-Video files sorted
=> Reading directories
=> Creating directories
=> Finishing
=> Checking discs
=> Writing to cache
===> Caching of files started
===> Caching of files completed
=> Writing to disc
===> Burn process started at 2x (2.770 KB/s)
=> Writing Lead-in
===> SCSI command aborted
PIONEER DVD-RW DVR-106D\H2 T0
===> Burn process failed at 2x (2.770 KB/s)
1A23-0075-4030-1531-4431-7835
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23-12-1997 03:23:24
ahead WinASPI: File 'C:\Programmer\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16-12-2003 19:18:06
Nero API version: 6.3.0.2
Using interface version: 6.3.0.0
Installed in: C:\Programmer\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <PIONEER DVD-RW DVR-106D>Version: 1.07 - HA 2 TA 0 - 6.3.0.2
Adapter driver: <> HA 2
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : FUJITSU MHT2030AT atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST RW/DVD GCC-4241N atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST RW/DVD GCC-4241 G: CDRom0
PIONEER DVD-RW DVR-106D D: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523496kB)
Free physical memory: 197MB (202056kB)
Memory in use : 61 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.5.2004
NeroAPI
21:19:36 #1 Phase 111 File APIProgress.cpp, Line 253
21:19:36 #2 Text 0 File Reader.cpp, Line 118
Reader running
21:19:36 #3 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-106D running
21:19:36 #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
21:19:36 #5 ISO9660GEN -11 File geniso.cpp, Line 3882
21:19:36 #6 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-At-Once, using DVD media
21:19:37 #7 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2269871 (504:24.71, 4433MB)
21:19:37 #8 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
21:19:37 #9 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: PIONEER DVD-RW DVR-106D, Media type: DVD-R
Disc Manufacturer: RITEKG - 03
Disc Application Code: 64, Disc Physical Code: 193
21:19:37 #10 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
21:19:37 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2269872 (2269872) = #2269872/504:24.72
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2269872 blocks [PIONEER DVD-RW DVR-106D]
21:19:37 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PIONEER DVD-RW DVR-106D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4648697856, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2269872 | lead-out | 1 | 0x00 | 0x41
21:19:37 #13 Phase 24 File APIProgress.cpp, Line 253
21:19:37 #14 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
21:19:37 #15 Phase 25 File APIProgress.cpp, Line 253
21:19:37 #16 Phase 36 File APIProgress.cpp, Line 253
21:19:37 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:19:37 #18 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
21:19:37 #19 Text 0 File Mmc.cpp, Line 19451
Set BUFE: supported -> ON
21:19:37 #20 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: No
21:19:37 #21 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
21:19:41 #22 Text 0 File Cdrdrv.cpp, Line 1277
21:19:41.119 - PIONEER DVD-RW DVR-106D\H2 T0 : Queue again later
21:20:05 #23 SCSI -500 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x06810000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
21:20:05 #24 CDR -500 File Writer.cpp, Line 301
21:20:05 #25 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
21:20:05 #26 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
21:20:05 #27 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 767
21:20:26 #28 Phase 38 File APIProgress.cpp, Line 253
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23-12-1997 04:02:46
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28-10-2003 12:02:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Error: Burn failed.
