Does anybody knows a software that tests whether the DVD contains any physical error?
For example, that could cause a possible freezing of the image, or skipping the video?![]()
Best regards,
Joelson. -
DVD Info Pro. Check the tools section to the left.
Hello Capmaster,
Thanks for the suggestion, it's a very good and easy-to-use software.
So if I run the test, and it results in no errors, I can be sure that the media is ok, and won't freeze or any other problems?Best regards,
Joelson. -
Originally Posted by joelson
Trial and error is the only way to feel confident, and even the smartest sage experts here would never make a foolish statement like "I guarantee that DVD will play in your player". In fact, the longer you're in this game, the more variables you see.
DVD Info Pro will be able to give you some data when comparing media brands. One note - test it using burns that are as close to a full DVD as possible, since many cheaper brands that have "dye spread" issues have many errors out near the edge. -
Capmaster, when you said "One note - test it using burns that are as close to a full DVD as possible, since many cheaper brands that have "dye spread" issues have many errors out near the edge.", you meant they print over the DATA area???
Best regards,
Joelson. -
Read Lordsmurf's great page on media:
www.nomorecoasters.com
He explains the brands, cross-brands. dye, etc. It'll help you understand it more than I could do here.
Real time test of media - whether I like it or not
By arcorob in forum MediaReplies: 12Last Post: 18th Feb 2010, 20:55 -
Test Pattern Generator software techniques and Display Adapter S-video Out
By cybertheque in forum Capturing and VCRReplies: 13Last Post: 27th Sep 2008, 00:35 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45 -
Starting Over Again..............Need Update on New Software and DVD Media
By jet757f in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 21:54 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 12:39
