I'm trying to use virtualdub-mp3 to check if my avi. movie has any bad frames.But when i try to open the avi. file in vdub-mp3, it gives me an error message saying, "cannot locate decompresor for format Xvid(unknown)", so after that i installed xvid.But it still gave me the same message.
Any help would MUCH appreciated!!
Not sure which version you installed but it wouldn't hurt to install the latest xvid codec.
yes, it does work on my PC.And i'm going to download the latest Xvid.....but what if downloading it, it still doesn't work, then what do i do??
You could always change the 4cc to DIVX(assuming you have Divx installed). There's a 4cc changer in the Xvid shortcut folder in your start menu.
...or you could try ffdshow...or aquire the move in some other format...
/Mats -
Originally Posted by loki17
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 08:35 -
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 19:23 -
How to playback BluRay plz ?
By Cov(enant) in forum Blu-ray RippingReplies: 2Last Post: 16th Sep 2008, 17:44 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52
