I have a couple of avi files that the quality are distinctly dodgy
Can I clean them up in Virtualdub so that the quality is much better or am I wasting my time
Is ther another program that will do the trick if Virtualdub wont ?
If virtualdub won't do it, not much else will.
There are tons of video editing apps, all promising to do magical things. They all do what vdub does, but with a fancier gui.
Check out the filters in vdub. I regularily use brightness/contrast, sharpen, and HSV adjust, especially on questionable quality downloads.Cheers, Jim
My DVDLab Guides -
You might want to play with the Temporal Smoother filter too.
OK guys thanx for tha pointers
just tried playing around with brightness/contrast sharpen controls etc..
what sort of settings should i put these to -
You're going to have to use the preview and adjust to your own tastes.
I find that sharpen more than 20 is useless.
Bright no more than 5%. Contrast to taste.Cheers, Jim
My DVDLab Guides -
The frame merger filter is a good general purpose filter for non-interlaced video.Available from
http://www.geocities.com/gc_timsara/vdub.html
It is a modified temporal smoother.
cleaning excessive noise with VirtualDub and Neat Video
By defiantclass1 in forum RestorationReplies: 11Last Post: 16th Aug 2011, 09:24 -
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 20:45 -
Join 18 .avi files with VirtualDub
By nlec in forum EditingReplies: 8Last Post: 16th Jun 2007, 00:32
