Results 1 to 14 of 14
    Oct 2003
    Southampton
    Hi,
    it seems to be more and more difficult to rip dvds, especially these new dark red/bronze ones. I use dvd decrypter or clad dvd 2.0 or clad dvd net 3.4.1. But whatever the ripping softwares, some dvds are just impossible to decrypt. Do you know of a stronger software, or a way round it?
  2. Banned
    Jan 2004
    Going in Circles
    try playing the dvd first for a couple of seconds. That should unlock it
    Oct 2003
    Southampton
    I always do that. But for some DVDs, it just doesn't do the trick!
  4. Banned
    Jan 2004
    Going in Circles
    sorry. That will usually do the trick because to play it has to be decrypted.
  5. maybe your drive is getting old/weak and cant read dirty/damaged discs too well.
  6. AnyDVD is software that takes out the protection. You could try that too. Or as mentioned clean your laser & make sure your disks are absolutely clean.
  7. try DVD43...it's free.
    Oct 2003
    Southampton
    Thank you all guys. T hat gives me plenty of tips to try. Whatever the result, I'll get back to you!
  9. Basically, if it can be played it can be ripped. It can't be a new type of copy protection, because all DVD players including the very first unit ever sold must be able to decrypt it to play. I use DVD Decryptor - it's a good package but you've already used it so it's pointless pushing it.
    Cobra
    Oct 2003
    Southampton
    Well, thank you all for your advice. But the actual 2 DVDs I want are still not on my Hard drive. I have tried with several copies of the same DVDs, all in good working condition. I have done others successfully in the meantime, so there is obviously nothing wrong with my hardware. I have tried everything you've all told me except for using 'charged for' softwares.
    So I still think there's some sort of special protection on them... And I won't get them!
    May 2001
    Why don't you tell us what titles you are trying to rip? Probably, someone else has had success with them - which would mean that your equipment is the problem, or that PEBCAK is affecting you.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Dec 2002
    Disable AutoRun and uninstall the anti-copying software that got installed without your consent (which is a violation of your rights, so get a lwayer and sue).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  13. try analyzing the dvd with dvdshrink???
    AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
    160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
    ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
    DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
