I want to author an out of spec DVD with a vob set larger than 4.3 GB and then DVD shrink it. What program can I use to author the vob set? Will Tmpgenc DVD Author do this?
Thanks a bunch,
Jason.
Hi touchdownfsu,
Yes, I believe TDA will do it - but it'll chuck up a warning message first. Click OK / Yes to ignore it and you'll get your VOBs etc.
I'm curious though - To be authoring, I'd guess you've got MPEG2 file(s) (.mpg, .m2v). So, if you still have the source that you encoded to MPEG, you'd be better off adjusting your bitrate to get a file(s) that fit without using DVDShrink.
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Yes, I am authoring an mpeg. So you're saying I should adjust the bitrate befor I author. How do I do this? Rejig maybe?
-Thanks. -
Hi touchdownfsu,
Did you encode a source file (say AVI of some description) to get the MPEG file? If so, use something like the DVDRHelp Bitrate Calculator to figure out your bitrate to get it on one disc, and redo the encoding.
If you've just got the MPEG file (say you've captured straight to MPEG) then, obviously, you can't re-encode. I'm not too familiar with this, so something like rejig or DVDShrink - both transcoders for recompressing MPEG to (smaller) MPEG - would do the job. Just a case of picking the best one... Can't comment on that, sorry!
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Possible to author a 23GB DVD onto a BD-R and play it on a set top box?
By litmus in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Feb 2010, 16:42 -
Do you need all VOB's in the set to be able to run VOB2MPG?
By ttucker in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Dec 2009, 12:24 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 20:10 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 15:30
