Im using the software Pinnacle Studio 7
It can play the video but when i go to capture it says error
what should i do
I've had the same problem, assuming that you are trying to capture from a DV camera. This is how i fixed it. I updated the software to the lastet update. I then downloaded this fix for the DV capture. Its on Pinnacle's website but I'm not sure where. I'll look for it. And if this doesn't work you might wanna try reinstalling your operating system. The latter should be your last resort. Also you might wanna see if other programs can capture. Hope all this helps. Some more information about how you capture and your system might help us alittle too.
alstatr -
I couldn't find that DV capture fix but the fix only works for the card that Pinnacle gave you when you bought Pinnacle DV 7, if you bought that. You might wanna try reinstalling windows.
I know it sucks but it might just do the trick.
Vegas Studio will not capture audio
By mpjbrennan in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2009, 10:24 -
ADVC110 to Studio 10 Capture
By jimlong in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2008, 09:41 -
Pinnacle studio 11 capture problems...
By bla4free in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2008, 11:09 -
Pinnacle studio 8 capture problems
By bimfi in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2007, 16:27 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
