I follow the VCD to DVDR w/ SVCD2DVDMPG+ guide to convert mpg video to 44.1KHz to 48 KHz file. Now here is the problem, I put all my sources file in c:\video and the output file in c:\video\dvd. Now after 6hrs of work now I get
c:\video
-sources.mpg(450Mb) <-old
-sources_DVD.mpg(470mb) <- new
and
c:\video\DVD\video
-video_TS.IFO
-VTS_sources_VOB(.99gb) <-new
According to the guide I can burn 450min of VCD in the DVD using VTS_... file. But when I try to use my easycd 6.0 dvd creator and drop in either sources_dvd.mpg or VTS_.... it say I only have 2gb left on the DVD.
What did I do wrong? Basically what should I do now??![]()
the video folder created by svcd2dvd can you burn directly but I don't know if easy cd can burn dvd folders, some guides for it here https://www.videohelp.com/guides.php?howtoselect=3;25#3;25
Maybe I don't say it clear enough. I have 40 source files, after the convertion I have 40 source files + 40 source_DVD file but there is only 19 VTS file.
Is that normal? Each of the source files is approx 45min(450mb) long and my orginal plan is to put 8 of those into each DVD. Is there anything I did wrong? -
I'm probably lost here but here is my lame theory. ok.
you have 40 source files @ 450MB per file (45 minutes each)
converting the audio to 48k isn't going to raise that size much. You state the new size is around 470mb each now.
A dvd blank will hold around 4400mb. The largest size vob files are allowed is 1.0GB. (probably your .99G)
So:
40 X 470mb = 18,800 total mb for the project.
18,800 / 1.0G = 19 vob files around 1G each. Actually 18 = 1G and 1 = 800MB
Since a dvd holds around 4400MB you can put 4 - 1G vobs on a blank. 19 / 4 = 4.75 or 5 dvd blanks required.
You said you have 19 vob files now. (I think). If they are around 1G each then you have a combined project.
Test play the vob files in a program like PowerDVD and check them out.
Probably wrong but hope this helps.
Good luck.
DVD Hardware Guide: mp3 wma crossed out. Means unit don't read that?
By TomBrooklyn in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2010, 06:26 -
Asafs TV Episodes to VCD-DVD guide
By angelheart in forum User guidesReplies: 4Last Post: 19th May 2008, 20:47 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:03 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
