Today I received the Canopus ADVC-55 analog to digital video converter. I know there are lots of favorable comments about the Canopus ADVC100 here but I thought someone might want to know a little about this lower-cost model.
It is just 3" wide, 5" long and 3/4" thick. It weighs almost nothing. Aside from its small size, what's cool about this is it is Firewire Bus powered. It comes with a Firewire cable. It only converts analog to digital; it does not output video back to tape. It has SVHS and video connectors and the audio jacks are RCA rather than stereo miniplug.
Toast 6 recognizes the box as a "camera" for direct capture into Toast. Naturally, it imports directly into iMovie as well. I also used Vidi which is a nifty freeware video capture application that allows programming start and stop times and can be set to automatically split files into sizes that work with iMovie.
I saw no problems with the captured video.
If you don't have a DV camcorder and want to capture analog to DV, I certainly recommend this easy-to-use little box.
Sounds like a nice little box. I think you meant S-Video, not SVHS. How's the video quality? How much was it? I paid about $250 for my ADVC100, it has very nice quality, and I have no complaints (unlike the ultra-crappy Dazzle Hollywood DV Bridge it replaced).
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Yep, S-Video it is. I think the box retails for about $250 and I got it for $200. The video looks great to me. I'll post back if I see any flaws. I want to test it out on some differing-quality sources and also see how the resulting DVD using Toast or iDVD compares with the results I was getting with my ADS USB Instant DVD for Mac. I've lost interest in the ADS box because it really wasn't saving that much time for what I was giving up compared with using DV as my source.Originally Posted by WiseWeasel
The ADVC-100 has audio lock and the ADVC-55 does not. I'll also let you know if this results in any audio sync problems. So far it does not.
My brother bought the Dazzle. It is now in a dump somewhere near Nashville. He was able to get it to work at times by first putting it in his freezer. By the way, I don't feel any notable heat on the ADVC-55 case. It has no fan and is totally silent (unlike the ADS box). -
Yeah, the ADVC100 runs cool too, and the locked audio feature is a plus. Let us know if you encounter any synch issues. The Dazzle unit was incredibly unreliable, and it actually fried 3 of my FireWire ports (one internal, one on a PCI card. and one on my PowerBook, which was thankfully still under warranty and had to get the motherboard replaced); they are to be avoided like the plague. Their customer support is nonexistent. The ADVC100 has been completely reliable, a real pleasure after the torture the Dazzle put me through.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 21:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 15:15 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
