I have started having a profound problem lately. I have been making the most coasters ever! I've made at least 5 in a row. All of my DVDs will not burn properly. I have read about the superdrives (pioneer dvrw /dvr105) lasers becoming misalligned etc. However I have read about toast being finicky at times. My questions are simple:
1.) Can someone write a basic burn with Disk Utility Tutorial. I have created a new dmg from my backedup VIDEO_TS/AUDIO TS directory, (and before everyone jumps on my back my file hierarchy's are fine and I have made at least a hundred backups flawlessly) so my dvd title is
DVDVOLUME and i have created a DVDVOLUME.dmg containting VIDEO_TS/AUDIO_TS. Then i have tried to burn and it burned but is not recognized nor ejected when i put in in either my g4s. Can someone help?
2.) Now that disccomvobulator is gone what can i use to split a dvd-9 into two to keep the quality and keep dvd functions? I ask this for movies like the last emeror almost four hours long so theoretically the video is already compressed.
I think i had another but cannot recall it now, any tips hints etc will be greatly appreciated. oh yes and I did burn successfully a cd the other day and am about to test a data dvd (I think the physical laser is fine)
Brian Takats
"I love jedi"[/b]
1. use DVDImager to compose a DVD-UDF format image of the VIDEO_TS folder.
2. mount the image and confirm it plays in apple dvd player
3. open Disk Utility [apps/utilities/disk utility
4. Go to IMAGES [in the top menu], choose BURN and select your disk image
off you go, couldnt get any easier
You might also try a different brand of DVD-R media. DVD2OneX can split DVDs without keeping any menus or other titles besides the main feature title using the 'join' mode (don't ask).
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I just followed your directions, and i did my test of the mount it worked perfectly. I brought the img into disk utility selected burn/verify. it burned properly but failed verification. after i reinserted the disc it did not even read it/or eject it. it is as though the disc is not even there.
Distressing
brian -
I didnt see what kind of media this is.
Sounds like its some media problem. Cheap media does this sort of thing. Hopefully its not a respected brand like TDK, Ritek etc. -
I have had problems with devices no longer mounting before. Running DiskWarrior by Alsoft solved the problem, I also repaired permissions and burned sacrifices at the altar of Norton. I'm assuming that your System Profiler shows your drive and that you can mount other DVD volumes.
New AVStoDVD user got some questions this software
By rock_king_my in forum Authoring (DVD)Replies: 8Last Post: 16th Sep 2010, 19:05 -
advanced (2:3:3:2) pulldown removal
By socalver in forum Newbie / General discussionsReplies: 6Last Post: 17th Aug 2009, 22:15 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 17:32 -
Linux questions from a Windows/OS X user
By LSchafroth in forum ComputerReplies: 18Last Post: 3rd Apr 2008, 00:36 -
A few questions from a new user
By stressbuster in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 30th May 2007, 20:19
