I attempting to put 5 hour episodes of a tv show on dvd using TMPGEnc DVD Author but it stops at about 30 % with an error saying it is going to make the dvd to big or whatever. This is usually not a problem considering i will just use DVD Shrink 3.1 to make it all fit........ what route do you all feel i should take to fix this......
the individual episode sizes are:
M2V File: 2.46 GB
AC3 File: 60.6 MB
You can't fit five 2.46 GB files on a DVD.Originally Posted by nitestalker49
I generally get TMPG to write an oversize ISO file to my hard drive and just click past the messages saying it is too large Then I get DVD Shrink to shrink it.
I have never had TMPG refusing to go any further with this method. -
The biggest to date I've did was 11+G. Author warned me (
) but I didn't care, I shrunk it later....
If the program is stopping at 30% then I would suspect a problem with one of the files...... That's where I'd start looking anyway.
Good luck.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGenc DVD Author 3 Maximum Size
By Shadowofthedarkgod in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 19:59 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
