Hi guys ! Did someone ever tried to encode some mangas or animation things on SVCD ??? (I'm using TmpgEnc) It's really hard on high motion scenes coz I get lots of artifacts and it looks really ugly ! I tried lots of differents encoding processes (2passVBR, VBR, CQ VBR, CBR,) But I have to stay below 2600Kbits/sec ! Does anybody knows if changing the GOP structures helps on high motion scene ? (like changing 1.5.2 to 1.3.2 ...) or maybe change the Matrix ? Thanks.
In TMPGEnc there's a setting in Quantize Matrix tab of the settings bit, normally it says default, click on the pulldown and choose CG/Animation. Also try adding a smoothing filter or something to try and break up the solid colour edges a little
Actually this web site would fit you completely I think
http://www.inwards.com/~dbb/
The only downside it's almost all NTSC based, but it's easy enough to "convert" to PAL -
I tried to change the Quantize matrix Tab to "CG Animation" but I didn't saw any changes in the resulting mpg...
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 08:23 -
StormCel Animation
By Noahtuck in forum Latest Video NewsReplies: 0Last Post: 26th Jun 2008, 21:09 -
animation to dvd
By J. Baker in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2007, 01:53 -
Cartoon Animation
By dbanga in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 11:46
