I have got a problem with authoring a home DVD.
Every time I create one the picture isn't good and it skips.
Would you please instruct me how to create a DVD from
a DV tape from the first step.
Originally Posted by roi123
For such a test I suggest you begin by capturing a fairly short dv tape clip, lets say about 5 minutes worth. Encoding that clip to mpeg2 using the supplied dvd template that most any encoding program ships with. For the burn test - I suggest you buy a DVD RW disk so you can erase it and use it over on your next test and use that. Take a few notes along the way so you always know what you did wrong....etc, and try to have fun.
If you run into a problem someone here will gladly help ya. But trying to explain every detail is a lot of typing......
Good luck.
p.s. and welcome to the forum....
