Hi.
I have gived up the dvdrbuilder. And found another guide on dvdr-digest.
And it is very good quality. But I have got some problem:
I have follow the quality dvd backup guide on dvdr-digest: http://www.dvdr-digest.com/articles/24_1.html . When I am done with it, and try to start the movie (with powerDVD open the video TS folder), I get to the movie menu. But when i start the movie , I get right in the middle of the movie. Seems that the start of the movie have disappear. But when I just try to start the first .vob file in the directory the movie start from the begining, but the menu is not there now. What can be wrong? Why do I get right into the middle when I start the movie with powerdvd? I now that I have loaded the file correct into powerDVD
Thanks for all help i can get.
sounds like sth got screwed up in your ifo files in the process... which I can't really say how if you followed the guide... try using the new guide that's around here (it doesn't use dvd-rebuilder and it's a pretty good guide) by matrixx or sth... it worked well for me
With all due respect... and there is respect...
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
How to save Re:Quality guide for HTPC, how to configure MPC-HC, ffdshow, et
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2011, 08:09 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
StaxRip Guide-w-Templates for High Quality XviDs
By Trac in forum User guidesReplies: 0Last Post: 24th Jul 2007, 01:53
