Is it a good idea to capture using XVID? The file size is considerably smaller than Huffy or Gpeg 1.0. I capture at around 2000 khz or so.
Anybody else try this?
Rog
XviD is a good choice if your not going purely for quality, or space is an issue. It has a much higher compression ratio than Huffman, at the cost of some video quailty. An XviD encode at 2000Kbps will look fine for most clean video. If your capturing from an analog source, you may see a drop in quality due to the noise that will invariably be present.
DVD Rips converted to XviD, however, should look very nice at that bitrate. II've seen excellent quality encodes with a bitrate as low as 900Kbps, or even lower, if you use Multi-pass encoding (not an option for captures).Impossible to see the future is. The Dark Side clouds everything...
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
