Results 1 to 10 of 10
  1. Hi im useing TMPEG pluss now it never use to do this but all of a sudden its started converting the video and audio separet meaning i get a video file then a separet audio file anyway to make it into 1 ? if u know what i mean. ?
  2. Bottom of window, check "System (video+audio).
  3. Thats already set at that pluss i use the start up wizard any other ideas ?
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Uncheck "Output video and audio as individual elementary streams" in step 5/5. Either that or don't use the project wizard.
  5. ok still cant fix it, is there anyway to join the audio as this is coming in 3 steps so i have 3 video files and 3 audio how can i join the audio so its all in 1 the video i know how to do but how do u join the audio ?
  6. Member teegee420's Avatar
    Dec 2003
    Southern California
    You tried both of my suggestions?
  7. if i dont use the wizard and just it as normal how do i know if its gonna convert it to dvd format ? soz about this i dont know that much about all this.
    Thanks for helping me though
  8. btw i cant Uncheck "Output video and audio as individual elementary streams its greyd out
  9. Member teegee420's Avatar
    Dec 2003
    Southern California
    Is the audio file that is created a wav file? If so you'll have to change the audio type to MP2 in step 1/5 in the wizard. Apparently TMPGEnc won't multiplex LPCM wav into an mpg file. If you want to choose the DVD template when not using wizard mode click the load button. To change any of the settings click the setting button. By the way, if you plan to author your movie to DVD you don't have to have the audio and video in one file. Most authoring programs allow you to import elementary streams.
  10. ahhhh thats what was wrong thanks man u was a big help
