I recently brought my 1st DVD burner and have had a load of problems with it. I managed to sort most of them out execpt 1. When I use DVD factory 2 to burn a converted avi to DVD it says that the disc is too small although it says that it is 4.4gb. DVD factory only needs 4.2gb, so there is more than enough room on the disc. Also I can not use DVD+RW discs in the drive as in explorer it says the disc has 0 space used and 0 in total. It also see the disc as a cd not DVDRW. I can however burn a disc to disc copy (DVD+R) in Nero which came with the burner. Windows XP can see the drive as a philips DVDRW824p although in my computer it says it's a cd drive. Anyone got any ideas.
The PC is:
Intel P4 2.6gb
768 RAM
120gb HDD
Windows XP Pro
DVD-ROM
Philips DVDRW824p
Results 1 to 1 of 1
ADVC Mini doesn't work properly
By keyboardboy in forum MacReplies: 32Last Post: 1st Dec 2016, 22:23 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 11:58 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 21:38 -
Can't get the .TS audio to work properly
By mkvbob in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 16:04 -
Can't get .mkv subtitles to display/work properly
By ChronoSquare in forum SubtitleReplies: 3Last Post: 26th Dec 2007, 15:36
