  1. hi people,
    how can i make my emac-drive region free???
    thx you
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    download VLC [www.videolan.org]
    its a software media player which is region free, it bypasses the need to set your drives region code, as apple dvd player requires
    so this way there is no patching/hacking of the drive
  3. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    See what model DVD drive you have using System Profiler (in the utilities folder in your applications folder), and see if they have firmware for it at one of these sites:
    http://forum.rpc1.org/viewforum.php?f=30
    http://superdrive.cynikal.net/
    If they do, make sure you follow the readme instructions VERY CAREFULLY.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systčmes, le cas d'application excepté."
  4. Is there a region free firmware for Apple A-04 or A07? Mine came w/ 1st version of flatscreen Imac (so it's an A-04 (I'm not at my machine) which makes it a 1X burner)). Is there any firmware to make it a 2X or is that impossible? (Man taking an Imac apart to put in a new DVDrecorder is a pain in ass (pluss void warranty)! Can't wait for the new G5s. But till then- any ideas? Burning at 1X eats my night up! Peace
    "What's a matter Colonel Sanders???? CHICKEN???!!!!
  5. Member WiseWeasel's Avatar
    Jan 2003
    There's RPC1 firmware for your drive here:
    http://www.opuscc.com/download/desktop.shtml
    Not sure if it changes the burn speed, though that is often caused by the type of media you buy. 4X media will burn at 1X. You need 1x or 2x media to burn at 2x. Be sure to follow the installation instructions very carefully.
  6. Member terryj's Avatar
    N35°25.24068, W097°34.204
    It won't change the burn speed, but it will make the
    drive not error out when burning to many brands
    of 4x media, including Ritek G04.
    Best on an A04 to go with media rated to burn at 2x,
    like TDK. Any 4x media wil still burn at 1x, because
    the specs for the A04 are set to burn at 2x max.
