I got a Hauppauge! WinTV PVR USB2, Tv-card&MPEG2
USB2.0 , Nicam Stereo, Retail and when trying to capture in virtualdub the following errors and messages occur, from top to bottom:
http://www.stud.ntnu.no/~stefanhe/vduberr.jpg
There are no processes running that uses the usb-card, I've also checked Services, I run Win XP Pro SP1, and nothing there either. I've also checked the wrapper and it is there. Anyone have any help to share?
Regards,
X.
Which version of Virtualdub are you using? It may be that your version just doesn't recognize the driver. Try upgrading to the most current revision, or get one of the all-in-one remixes, like VirtualDubMod.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
It seems to me as a vfm2wdm wrapper problem
Use virtualvcr to get picture on your PC. Close Virtualvcr, run virtualdub.
Sometimes this way you overcame this problem.
If not, then you may forget virtualdub for capture.... -
Yeah, I tried that one aswell, and no picture and no nothing there either.Originally Posted by SatStorm
Capturing in mpeg2 works without a hitch tho', with the bundled software.
Ahwell... thnx for quick answers tho'
Regards,
X.
Hauppauge USB live 2 capturing with virtualdub and lagarith
By rudolf016 in forum Capturing and VCRReplies: 13Last Post: 14th Apr 2012, 10:14 -
Help with Virtualdub and Pinnacle MovieBox 710-USB
By cgarai in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2012, 00:14 -
Ati 600 usb stick and virtualdub capture
By buckethead in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2011, 16:13 -
Diamond ATI Tv Wonder 750 USB and virtualdub
By buckethead in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2010, 03:34 -
USB problems
By alintatoc in forum ComputerReplies: 0Last Post: 8th Feb 2010, 03:40
