Results 1 to 13 of 13
  1. hi!
    i've been trying for q few days now, to encode my video files to .mov with quicktime 6pro (like apple trailers)
    i can do it, but the quality its no so good
    or the file size it very high
    my question is
    if anyone know which setting should i use..
    for my video files (2 minutes) look good and dont have a high file size
    what i basically want is them to look like common apple trailers...
    thanks a lot!
    Increase knowledge, increase sorrow.
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Which format are your input files in? I would recommend that they be an uncompressed AVI or DV file, as the Quicktime compresses the file, and if your source is a MPEG or other already compressed format, the result will look worse than what you started with.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. ups, i forgot to mention that..
    they are in uncompressed AVI
    thanks
  4. i want to believe
  5. tra la la
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    use Sorenson Squeeze 3 Compression Suite -- with Sorenson Video 3 Pro codec and 2 pass VBR
  7. thanks, i'll give it a try...
  8. i tried sorenson but wasnt able to make a mov with sound if i use a vob file as source
    any ideaS?
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Vob files a. aren't uncompressed. The video contained within them is compressed with mpeg-2, and b. may contain more than just video, which can cause problems.
    I would suggest demuxing the video and audio out of the vobs, and going from there.
    Read my blog here.
  10. Член BJ_M's Avatar
    Jul 2002
    Canada
    on May 10, 2004 you said they were uncompressed avi ...
  11. yes it works fine with uncompressed avi, now i'm triying with vobs
    the vob i use has pcm sound, not ac3
    dont know why i cant get sound
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    demux it as suggested - but i am pretty sure you will have to convert the pcm to wavs for squeeze to work
  13. i've already tried that
    but in squeeze 4 if i open an mpg, and i want to import and audio file it has to be the same time of the source (mpg)
