I have a 733 p3 and I capture using a dc30 pro to 60 gb external ADS kit firewire drive with a 5400 rpm hd inside.
Are kit firewire drives just inferior?
Should I just live with it?
Should I swap the internal drive to a 7200 rpm?
Should I get an internal ATA?
The general rule is that you need a 7200 rpm to capture without dropping frames.
Where did you come up with that rule?
You can definitely capture without framedrop on a 5400 rpm drive if you are using some sort of AVI compression.
imdanwhou, that is quite a small frame drop... Does it interfere with the video playback in anyway (e.g., skipping). If you don't even notice it, I would just live with it.
Regards.
Michael Tam
w: Morsels of Evidence -
As virtualis says that's nothing to worry about, your gonna drop a few frames (windows media player drops something like 14 every 200 on playback, check in the properties if you don't believe me).
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 12:02 -
Avisynth drops blank frames?
By wfael in forum EditingReplies: 3Last Post: 9th Dec 2008, 22:06 -
NetFlix Drops HD DVD
By MOVIEGEEK in forum Latest Video NewsReplies: 24Last Post: 13th Feb 2008, 18:17 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
