Hi,
I have a Sony TRV 140 (Digital8)
and when I film some scene with sufficient movement or make a faster movement with camara(Traveling) the DV image, gotten after passing the film with the fireware card to the PC, is'not clear and the contours of the figures are with small horizontal traces. Why this happens? How can I solve this problem?
Thank's
AC
Welcome to the forum AC
The problem with viewing interlace video on the PC is the horizontal streeks on movement. This is normal as the PC is progressive scan.
I have the same camera and when I capture with composite input it looks normal on the TV out of the video capture card (Matrox G400). But when I capture using FireWire the field order is reversed on the same capture card TV out and looks stroby. Are you judging the video on the PC or TV out?
Anyway, when encoding to MPEG with TMPGEnc, use bottom filed first and all will be well again.
Chas -
Hi,
I see those horizontal streeks on the PC, in the TV I don't see so but this movement give a not clear images. I have another analog camera, Sony TRV 48 and the movement images are more clear.
What you mean about to use "bottom filed" with TMPGEnc ?
I use TMPGEnc to encode the film but if I convert to DVD, for example, I continue to see those "horizontal streeks", only encoding to MPG1 (VCD) that all it's fine.
What it's the better configuration, or must I capture from my TRV 140 not with FireWire but with Composite?
P.S. My english is not very good, so I'm portuguese.
Thank's
AC
quality difference hi8 vs digital8 tapes
By avmaster in forum Newbie / General discussionsReplies: 4Last Post: 23rd Apr 2012, 15:20 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
Digital8 to DVD Quality Issue?
By robbieturner in forum Authoring (DVD)Replies: 12Last Post: 8th Sep 2009, 06:23 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 22:28
