    Dec 2002
    i capture my VHS tapes using my canopus 100 using WINDV then use tmpgnc to convert,then tmpgnc dvd authour to author, For the menu backgrounds i use stills captured from a roughly authoured output . but sometimes i cannot get a good still capture sometimes, ie it captures between two frames giving a blurred look to the still, but on the odd ocasion its fine. is this a problem that can be solved by adjusting a setting in WINDV or is it just a source tape problem or maybe a different setting in tmpgenc plus
    Mar 2003
    Uranus
    Would you say your chances of getting a bad one are about 40% ?
    You are probably having interlace and/or telecine problems.
    Not much to do about it except capture several in a row and pick a good
    one.
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    Edit your capture in Virtualdub and then output as images, you're bound to get one to your liking. Or use TMPGENC, that outputs images too.
    Dec 2002
    i do use tmpgenc and ur right, i do get about 40% decent stills, so i guess its just pot luck as you say. Thanks for the advice guys
    Mar 2003
    Uranus
    That's not pot luck it's 3:2 pulldown or telecine.
    there are 2 mixed up frames out of every 5
    edit: wait a minute , you should get 60% good ones
    Dec 2002
    is there any way to avoid 3:2 pulldown or telecine or is it just a factor of VHS capture, by the way i always get perfect stills of storebought VHS tapes, why is that
