Well after digging through possible solutions and other ways to get this to work I finally found a fix.
I burnt a SVCD out of home movies with probably 10 different SVCD encoders (including the latest Ulead DVD factory) and each time I play them, they skip (or pause). I went to circuit city with my cd's and they skip their too. I was ready to pay big money for a dvd that would work as I thought they were all flawed.
What I found out was that all SVCD are encoded via a variation up to 2500 kbps.
So I used the DVD factory encoder (I'm sure any will do) and created my own encoding.
480X480 (standard for SVCD) and encoded it at a constant 2500 KBPS. I tested this on my DVD (JVC 65 something) and on other makes at Circuit city. It worked beautifully. Even worked on one of thier models that costs only $149.
Good luck, and email if you have any questions with burning SVCD's. I have alot of practice now.
Results 1 to 1 of 1
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 17:02 -
Door/tray stuck problems.... solution?
By garybeck in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jul 2009, 16:09 -
Long time burning and skipping problems
By championjosh in forum DVD & Blu-ray WritersReplies: 8Last Post: 16th Feb 2008, 01:11 -
Playback problems when manually skipping
By vanquish42 in forum Software PlayingReplies: 3Last Post: 6th Feb 2008, 05:36 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17
