I used to buy TDK media made by TY but now I can only find TDK made by CMC.
Verbatim made by MCC are hard to find while Ritek G04 is very common.
Based on ur knowledge and experience I'd like to know if there's any big difference between TY/MCC/RICOH and RitekG04.
I just want to know if TY/MCC/RICOH is worth the trouble to get them.
Give a person a fish and you feed them for a day; teach that person to use the Internet and they won't bother you for weeks
Have you noticed that a slight tax increase costs you two hundred dollars and a substantial tax cut saves you thirty cents? -
check lordsmurf's site: www.digitalFAQ.com/media/dvdmedia.htm
It may be a hassle to track down your favourite discs but it is worth it. I have had endless trouble with bad burns (failure to verify, glitches on playback, players not playing discs) so l had to track down some ricohs/ritechs, and since have had much fewer problems. In the long run good Quality discs are cheaper as you chuck less of them out. Maybe in a year or so discs and burners will have evolved to the same state that cdr and cd burners are at!
My G04's are made by Ritek. Simply the Best.
Media Information
Region info N/A not a DVD-VIDEO
Media code/Mfr ID RITEKG04
Formatted Size Blank
Total Size 4.38GB(4.71GB)
Book Type DVD-R
Media type V2.2 DVD-R
Write Srategy Speed 4.0x 5540KBs
Media Id Code Speed Unknown
Current Drive Speed 4.0x 5540KBs
Default Rotation Control CLV
Linear Density 0.267um/bit
No of Layers 1Geronimo -
Goto RIMA.com and get some TYs, they are move expensive, like 1.35ish in a 100 pack but they are first class 4x disc.
I"m staying away from Ritek for a while after some of the recent quality issues we've seen. -
If I buy online in a store outside EU, I have to pay some taxes plus shipping fees and that makes the media way too expensive.
Is there any good european online store?. My preference is for those based outside UK.Give a person a fish and you feed them for a day; teach that person to use the Internet and they won't bother you for weeks
LG GSA-E60L or GH22NP21 does not burn MCC-004-00 well.
By Vianty in forum DVD & Blu-ray WritersReplies: 4Last Post: 30th Sep 2011, 04:49 -
Long-Term Storage - Verbatim DVD-R 16x (MCC) still BEST/IDEAL ?
By quantass in forum MediaReplies: 7Last Post: 29th Jan 2010, 01:14 -
Pioneer DV-400V won't read Verbatim MCC-004
By unknownsoldierX in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2008, 15:55 -
Different printable MCC 03RG20 brands?
By burgul in forum MediaReplies: 5Last Post: 19th Dec 2007, 09:11 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
