Results 1 to 12 of 12
  1. Hey everyone, I have been tryin to get my Band of Brothers video collection onto DVD and they are all compressed as .avi right now... When I use TMPGenc to convert them to mpeg, it says that the file cannot open, or unsupported. What does this mean? It is just a regular .avi file!
    -merc
    SYSTEM SPECS:
    : Abit NF7-S v2.0:
    : Corsair 512MB XMS DDR3200 :
    : AMD Athlon XP 2600+ at 2.01 :
    : 80 GB WD HDD 8MB Cache :
    : Antec LANBOY Case 350w PSU + 2 80mm fans :
    : Sapphire ATI Radeon 9800 Pro 128MB :
    : LiteOn 4x DVDR/RW :
    Apr 2002
    The State of Frustration
    How did you get them onto AVI, and what have you tried so far?
    Hello.
  3. When my dad transferred them from his computer to mine they were all in .avi format... They play fine on my computer and whatnot... All I have tried so far is converting it to mpeg using TMPGenc... any suggestiosn
    -merc
    SYSTEM SPECS:
    : Abit NF7-S v2.0:
    Apr 2002
    I am trying to figure out the codec. How did Dad get them on his computer?
    Hello.
    Dec 2002
    My Swamp
    Get Gspot or AVICodec It will tell you what codec you need for the files.
  6. Mod Neophyte redwudz's Avatar
    USA
    Why do I always suspect DIVX when I read these type of posts? I see andyp1 beat me to it, but rbmerc, see what format they are.
  7. k ill try that gspot and find out what codec it is... more info soon
    -rbmerc
    EDIT: UPDATE -
    File : 695 MB (695 MB), duration: 1:13:12, type: AVI, 1 audio stream(s), quality: 56 %
    Video : 629 MB, 1202 Kbps, 23.976 fps, 640*352 (16:9), DX50 = DivXNetworks Divx v5, Supported
    Audio : 66 MB, 127 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
    What now?
    SYSTEM SPECS:
    : Abit NF7-S v2.0:
    Dec 2002
    My Swamp
    You need a Divx5 codec.
    Have a look HERE
  9. man i am the biggest nub, i forgot to reinstall divx after reformatting my computer a few days ago, thanks tho for the help! lol
    -merc
    SYSTEM SPECS:
    : Abit NF7-S v2.0:
  10. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    You so did not get those AVI files from your Dad otherwise he would have just backed-up the DVD discs directly no need to go DivX AVI route.
    Stupid.
    Leave the Warez at the door next time.
    - John "FulciLives" Coleman
    Apr 2002
    He would have to be to put his father in his untruth.
    Hello.
  12. ok believe what you want
    -merc
    SYSTEM SPECS:
    : Abit NF7-S v2.0:
