Hi,
I am new to converting AVIs to DVD as I just got a new DVDRW drive. I manage to convert a movie in AVI to DVD with subtitles using numerous tools from tutorials on numerous sites including here.
I have a question about handling movies that comes with 2 AVI. How do you guys handle it and calculate it's bitrate to encode to MPEG2?
Do you combine the files into 1 movie first then convert to MPEG2 or convert each file seperately and handle it's subtitle likewise?
Is there any tutorial on this subject?
convert each separate. you calculate the bitrate for the total runtime of both clips. joining just cause problems.
hmm..how does then the 2 mpeg2 files handled when creating DVD vob files?
I create them using IFOedit which doesn't seems to handle multiple video files.
But if I use tmpgenc dvd author, which handles multiple videos, it doesn't handle subtitles. -
Use VirtualDub. First demux if audio is mp3 VBR. The remux video with wave. Then open the first avi and select "Append avi" in the FILE menu. then select "Direct Stream Copy" in the Video menu. Then save this AVI. I just did this procedure last week and it worked. With the big AVI i used TMPGenc to encode to DVD !
Good Luck.
HD TV Best Deal for 40-50 in HD TV? I have no clue about TV's
By sandman423 in forum Newbie / General discussionsReplies: 17Last Post: 14th Jan 2012, 23:33 -
To many .ISOs to deal with
By jclarkyyy in forum DVD RippingReplies: 12Last Post: 20th Jan 2010, 23:56 -
2CD Quality Encoding.
By scott274 in forum Video ConversionReplies: 5Last Post: 17th Dec 2009, 19:05 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55 -
Deal or No Deal
By dairymann in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 14:46
