Hello, i know there's loads of similar topics but all the devices seem to be US based so does anyone in the UK have any sucess with a device over here? I've purchased a provsion box which can be seen here http://www.consolesandgadgets.co.uk/catalog/product_info.php/products_id/1455?osCsid=3...3f37a51359ca3f
I bought it on good reccomendation that it works but i'm still getting the "you cannot copy this material" when trying to record from a standard PAL video to the Panasonic DMR E50. I'm using 2 scarts and the box is switched on but the DVD recorder still won't allow me to copy macro protected tapes.
Does anyone have this unit that has worked for them or can anyone point me in the right direction if i'm doing something wrong or perhaps find me a box that definitly works alongside their E50?
Any help is much appreciated.
Wayne
Cheers
Wayne -
I used the Sonel Macro Master Pro lead on my E50 to back up all my VHS tapes and some DVDs, no problem with any tape not recording.
Even works with recording movies from Sky box office.
www.sonel.com
Hammy -
"hammy" the "Sonel Macro Master Pro lead" does it still keep the closed caption Subtitle's ever Macro remove I used rip's out the Closed Caption subtitle's also.
"grapplingpunk" I do not think it matter about the macro remover being NTSc or PAL.
I use Sima box for VHS to PC and www.facetvideo.com for VHS to DVD recorder. -
Sorry for the delay, had to check a few discs first, to be honest it wasn't something i had really thought about.
No it doesn't seem to allow them through, judging by the ones that i've just checked, that included a movie from sky box office, you just get what's on screen.
Hammy
Is this macro-blocking?
By txporter in forum RestorationReplies: 12Last Post: 15th Mar 2010, 07:07 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
HQ Macro-Plus.....
By TheGMan in forum RestorationReplies: 3Last Post: 4th Aug 2008, 20:49 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 13:34 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 03:12
