Hello. Anyone has any suggestion for backing up The Last Samurai? I opened it in DVD Shrink and it is compressed to 51.9%![]()
Results 1 to 20 of 20
I used Nero Recode. I backedup just the movie and cut off most of the end credits. I managed to get the compression to 69%
I used shrink and did it at 51% with the deep analysis but I don't think it makes much of a difference. Some will say it does but I couldn't tell.
I ran the movie through DVDShrink with the movie only and only the needed soundtracks with No Compression. Then I used the input from that to encode with DVD Rebuilder. Stunning.
I backed it up to 2 discs for disc 1 using DVD decrypter, then splitting and burning with Intervideo DVDcopy, and then backed up Disc 2 using DVD shrink and all was well.
Back up to 2 discs, best method to not lose quality.
Other than that, buy the new Benq DL burner, spend $$ for some dual layer DVD+R and copy with no loss!
Just make sure to label the backup correctly as 'The Penultimate Samurai'.Originally Posted by zoneless
for those using recoding methods - don't forget the forced subs (unless you understand japanese that is ...
- on the R2 they are 2nd set of subs not the first (in their own sub stream).
Just did it myself using DVD2SVCD with the RobA plugin (one pass VBR with a result that matches 4-5 pass CCE), used Vobsub to create the forced subs, IfoEdit to create the vobs and good old Nero to burn.
For a long movie - I am very impressed with the quality I achieved - soooo much better than DVDShrink.... -
AgreedOriginally Posted by bdf24
Although Teeeerex provides food for thought.
How do you backup your o/s?
By johns0 in forum PollsReplies: 23Last Post: 6th Apr 2011, 06:31 -
japanese subtitles on Last Samurai
By sorethumbs in forum DVD RippingReplies: 2Last Post: 21st Sep 2008, 20:09 -
backup question
By rcguy1 in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2008, 13:16 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 09:38 -
I can't backup one of my DVDs
By Cunhambebe in forum Newbie / General discussionsReplies: 11Last Post: 9th Sep 2007, 03:15
