I have a BIN/CUE set made of an SVCD. I can burn the image onto a CD-R using Roxio ECD 6 (disc copier). I can then play the SVCD with PowerDVD.
What I would like to do is extract the BIN/CUE onto my hard drive and play from there (i.e. skip the burn process) - or just extract the MPEG2 file if that's all I need.
I've attempted the extraction with ISOBuster however I get an error when trying to extract (see image) - (even though it works fine since I've burned it to a CD-R.)
So, if anyone has a simple way to do this, I'd appreciate the input.
Another simple way is to figure it out myself (inadvertently)
In ISOBuster, I selected "Extract but FILTER only M2F2 MPEG frames," then navigated to the MPEG2 file and opened with PowerDVD which worked like a charm.
For the record, I searched thoroughly for a solution to this and never found that FAQ. Thanks for the input, however. -
If you ignore the error, the file will still play at the end.
Actually, the link to Daemon Tools in the FAQ (where it's called Virtual Daemon) is broken/outdated, and has been for almost a year. It needs to be updated as it has been in the Tools Section.
btw, daemontools changed their homepage to http://www.daemon-tools.cc
Posted July 06, 2003 by mysticgohan17. Tool version 3.33 using OS Win2K -
you can play the bin file with videolan
https://www.videohelp.com/tools?tool=217#comments -
Actually, what also works is that you could put: Extract raw but convert to user data. that works nicely also.
Best way to play Blu-ray rips from a hard drive
By idsane in forum Blu-ray RippingReplies: 10Last Post: 12th Apr 2012, 16:46 -
Copy/Play HDDVD's from your hard drive
By joepic in forum Blu-ray RippingReplies: 20Last Post: 31st Jan 2012, 04:31 -
How to play HD Video from Hard Drive to Bluray
By jbitakis in forum Authoring (Blu-ray)Replies: 51Last Post: 14th Nov 2011, 15:43 -
Browsing hard drive DIRECTLY with Patriot Box Office
By i am x in forum Media Center PC / MediaCentersReplies: 5Last Post: 7th Jul 2011, 23:38 -
Capture directly to dvd, no saving to hard drive
By some dude in forum Capturing and VCRReplies: 8Last Post: 20th Jan 2011, 12:03
