I am trying to convert an AVI file I have captured from a VHS tape to divx 5. The captured file is 10GB long and is 6000kbps and using mjpeg compression. When I set up virtualdub to convert this it completes all the settings and I can scan through the file to see the resultant output using the scroll bar, however when I go to start the conversion I get the message "Cannot start video compression - The source image format is not acceptable (error code -2)". When I change the compression codec to anything else I have installed (including dixv 3.11) it converts no problem. I have tried installing/re-installing both divx 5.05 and divx 5.11 and both give the same result. How can the source file be incompatible for just divx 5 ? Is this a known codec error I can fix or am I destined to use divx 3.11 forever ?
What is the resolution of the video?
DivX is most happy when the height and width are multiples of 16. -
Thanks for the reply. I have tried capping at 720x540 (cropped) and 720x576 and both these resolutions give the same error.
Sorry, when i asked for the resolution, i meant the output resolution. Your creating a AVI file of what height and what width?
DivX 3 will allow resolutions that are illegal in DivX 5. To encode the same video from DivX 3 to DivX 5, you'll need to either stretch, or letterbox your output.
Here's a VDub resize filter that supports letterbox.
http://neuron2.net/resize.html -
Thanks again. The output resolution I am trying to use is 600 x 400. An odd resolution I know, but that seems to be what the BBC use for their "16:9" programs ! I have just tried a clip I have in 4:3 and converted it to 640 x 368 and it worked great. Looks like I will have to letterbox from now on. Thanks ever so much for your help
Error in Virtualdub while converting mkv to avi
By anchonio in forum Video ConversionReplies: 6Last Post: 1st Aug 2011, 02:36 -
ffdshow + MJPEG + VirtualDub = Blue Man Group!?
By VideoCynic in forum Video ConversionReplies: 2Last Post: 8th Jul 2011, 16:33 -
Combining and converting AVI (MJPEG) files
By vikasa in forum Video ConversionReplies: 0Last Post: 21st Jun 2010, 12:47 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Divx/Mjpeg to Mpeg-4 with VirtualDub
By nalooti in forum Video ConversionReplies: 2Last Post: 16th Nov 2007, 22:50
